Blue yeti microphone not working anymore
Hi ! although the Blue Yeti microphone is correctly recognized both by windows 10 and audacity, the message “Error code 9999 unanticipated host error” appears when trying to record. Windows trouble detector does not find any problem. The mic is set on MME and 44800 Hz, other setting does not solve the problem, the Yeti pilot is the latest one; Any idea ? Thank you in advance
L’appareil USB\VID_046D&PID_0AB7&MI_00\6&5a64ad&1&0000 n’a pas été migré à cause d’une correspondance partielle ou ambiguë.
Dernier ID d’instance d’appareil : USB\VID_046D&PID_C534&MI_00\6&1b88083c&0&0000
GUID de classe : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}
Chemin d’accès d’emplacement : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(1)#USBMI(0)
Rang de la migration : 0xF000FFFFFFFF0023
Présent : false
Statut : 0xC0000719
Try another USB cable (probably not the problem) and check your Permissions/Privacy Settings.
The error codes are explained at the bottom of this page but it only says what I repeated above. :frowning:
You can also try Listen To This Device to make sure Windows is getting a signal.
