Hi has anyone use blue snowball for dictating your voice?
Lenny
Lenny
I have. We had one at work. It’s a plain condenser USB microphone with three options on the rear. People usually want Position 1 Cardioid. That means it’s directional. You speak into the company name.
Did you get the little stand with it?
If it came with a USB cable, you should use that one or something shorter. USB cables cannot be safely extended.
Plug the Snowball in, let it settle a little and then launch Audacity. If you have Audacity running first, it may not easily connect to the Snowball.
Thanks
