The “original version” has just 2 controls.
The " Latest version" (at top of this page) has more controls and is probably the version that you want.
I will say before you replied, at some point i finally got it working. Although the latest version was the first one i clicked when i had the issue
I installed it, but I can’t see it. I tried fidgeting around, and now I can’t see any imported effects! Can someone help me, please?
For recent versions of Audacity it is necessary to restart Audacity after installing new plug-ins.
when i try to use the bitcrusher, it says the available range for output level is 0.000000000 to 0.000000000. does anyone know how to fix this?
If you are using the " Latest version: BitCrusher.ny", then the “Output Level” must be in the range 0 to 1.
yeah, but its… not. im using version 2.1.1, if that helps.
Audacity 2.1.1 may be too old to run the Bit Crusher effect. The oldest version it was tested with was 3.0.2.
May I ask how you install this bitcrusher? I’m new to Audacity
With the Nyquist Plug-in Installer.
