I am using Audacity 2.3.2 on Windows 10 Enterprise (Version 1703, OS Build 15063.1805). I have been recording bird songs as WAV files using Voice Record Pro on my iPhone 6s with the end result to add them to the eBird.org database. (WAV are preferred by eBird.)
eBird’s guidelines say to “normalize” or “boost” the sound of recordings: “Adjust the level of each sound file so that the loudest bird sound reaches -3 dB.”
I think I have figured out how to do that but want confirmation from other Audacity users.
What I’m doing:
- Open file.
- Ctrl-A
- Effect → Amplify
- Set “New Peak Amplitude (dB):” to -3.0
- OK
- File → Export as WAV
- Save as type: WAV (Microsoft) signed 16-bit PCM (the default that comes up), SAVE.
- OK (on “Edit Metadata Tags” - haven’t made any changes)
Sometimes, somewhere on a track, -3.0 dB has already been exceeded. Is going through the steps going to enhance the recording or make it unnecessarily softer?
I know how to Trim files by:
- Place cursor at boundary. (It seems you have to be very precise as to how high on the line you click to place the cursor. Too low or high and it starts playing instead.)
- Select → Region → → click on Trim icon
On one recording, there was some wind when recording. It resulted in a couple of very high, but narrow spikes in the sonogram (?). Is there an easy way to manually shorten those spikes so that the normalizing isn’t affected by those? I see how to “Silence audio selection”, but ideal would be to not have a blip of complete silence. (I could attach a file of that would help.) (And if you think I should post this as a separate, new post, please let me know.)
In another recording there is a distant lawn mower noise throughout. Any easy way to get it out?
In another recording someone is talking for a couple of seconds–easy way to get it out?
Thank you!
