Hi, I’m new so sorry if this is really basic.
I have a song that I’m trying to extend. Eg it’s currently Beginning Middle End, and I want it to be Beginning Middle Middle Middle End.
I’ve tried splitting, copy and pasting but it feels really clunky and I’m not sure I’m doing it quite right.
leave a little excess for overlap, then crossfade …
https://manual.audacityteam.org/man/creating_a_crossfade.html
I won’t attempt to give you the exact steps, but I’d do something like this.
Open the file, then Tracks → Add New to create two more empty tracks.
Copy the music into all 3 tracks. (When you play or export they will be mixed.)
You can delete from (or “silence”) each track to make beginning. middle, and end sections.
You can also click & drag the name above each track to move it around time. Zoom-in for more precision.
Leave a little extra audio so you can make a short crossfade for a smooth splice. Maybe start with a 0.1 second crossfade, but you can go longer or shorter for whatever sounds best.
This will most-likely require some trial-and-error.
Or you might want to make the 1st splice first, export as a temporary file, then re-open and add the end section.
