Yes, I understand that. But it depends. Let me explain a little more fully. In a year or so I’m going to retire and move a few thousand miles to a smaller house. I can’t bring all this stuff along, so I’ve been doing a little converting over the last two years.
I’ve converted 500 7" reels (almost all at 3 3/4), 100 10" reels (no, not 15ips, 3 3/4), over a thousand cassettes, at least 100 DATS, and ripped thousands of CD-Rs (using EAC). Almost all of these are non-commercial; either radio broadcasts, audience recordings, outakes, soundboards, that kind of thing. I’m now working on a few hundred cassettes that I taped live over the last 40 years.
So the quality is usually not the best anyway. These albums tend to be records that I bought when I was a kid, didn’t treat particularly well then, and probably haven’t heard in 40 years. They’ve been in boxes in the basement. I just did Cream - Wheels Of FIre, which is annoying because it’s four sides. Heh, at least I don’t have one of those turntables that stack records and drop them one after another! Anyone old enough to remember those? Hey, that’s not a bad idea, that would speed up the process.
My cousin tells me that I’m nuts to be digitizing vinyl, that they sound better than CDs. Well yes, with his system, and high quality classical recordings, I agree. For my crap? Not so sure. I didn’t even have a working turntable until I decided that it was time to begin processing the records. And I haven’t figured out how to scan or photograph the jackets and inserts and stuff. I’m thinking about buying a used professional scanner that will handle 12 * 12.
So, really, since I also have a bookcase filled with regular old commercial CDs that I’d like to rip, oh, and a few boxes of bootleg vinyl albums, I just can’t spend even an hour fixing each album. I’ll die first. In fact I attached a timer to the turntable so in case the record skips back, it will shut off before ruining the stylus, I hope. I hooked up the timer after doing just that, but I got a better stylus. 30 minutes, then cut the power.
Anyway, I was just sort of hoping that there was a simple way to, well, stick track 2 at the end of track 1. I’ll happily keep the few seconds of blank time. Really, right now, I’m selecting the second track, trying not to miss the start or end, and copying, then moving to the end of Track 1, pasting, and hoping that I got it right. Not the end of the world, but a bit annoying.
