I selected Turn on app permission for Windows 11. Everything was ready.In the Audacity menu which is in Italian I can’t find the "transport–>rescan audio devise setting
HI,
Hi,
yes I did it and I get these devices from the mixer, which otherwise, when the mixer is not connected with USB, are not visible.
microphone (USB audio CODEC)
Speakers ((USB audio CODEC).
It only works if I record from the PC (e.g. YouTube) but not with the microphone or guitar connected to the mixer.
I can’t see why it is not working. From the 1622USB manual:
The XENYX mixer line has built-in USB connectivity, allowing stereo signals to be sent to and from the mixer and a computer. The audio sent from the mixer to a computer is identical to the MAIN MIX.
I would think you want to record from “microphone (USB audio CODEC)”.
Are you getting any audio output from your mixer (MAIN MIX)?
