Batch convert multiple Flac to mp3 files
use 3.6.4
  1. I Use batch convert to get smaller size from Flac to mp3 /320 kbs to reduce size
  2. I use funtion “Import Sound Cntl/Shift/I” to import multiple files. Ok
  3. then i select all files cntr/A
  4. then starts problems. directory to output mp3/320 kbs export is complicate to find and old dir from last session is shown. Conversion is OK but new name mp3tag is wrong - adds prefix of last file to all mp3tag fienames so mp3 tag is wrong
  5. can be done anything to get simple way .
    thnks :wink:
If you are on Windows, try Kabuu Audio Converter. Once you’ve set up your output format & destination it’s just drag, drop, and click, and you can batch convert multiple files.
Your tags should be better preserved. (It’s a “weak area” for Audacity.) But they might not be perfect because they use different tag formats. FLAC uses Vorbis comments and MP3 uses ID3.
…I’m seeing LOTS of ads on the Kabuu download page so make sure you’re downloading Kabuu.
