Hi,
Under the new version, how can I replicate the effects of a bass and treble boost without the equalization feature? I’ve tried the Bass and Treble control, but the sound is not close to being the same.
Thanks,
Hi,
Thanks,
The old Equalization effect has been split into two effects.
If previously you used the “Graphic” mode, you now have “Graphic Eq” (this will be improved in the next Audacity release): https://manual.audacityteam.org/man/graphic_eq.html
If previously you used the “Draw” mode, you now have “Filter Curve” (this will be called “Filter Curve EQ” in the next Audacity relase): https://manual.audacityteam.org/man/filter_curve.html
