Balance setting of Windows 11
Hello :slight_smile:
I need your help: Every time I open Audacity, the software changes my audio settings in Windows 11. For example, I have set the stereo balance in Windows 11 so that the left speaker is 4 steps louder than the right speaker.
When I start the program and also after I close it, the stereo balance is reset to 0.
This is annoying when using Audacity, but also during regular use of my PC since the left speaker is further away from me. Constantly going into the system settings to correct this is frustrating in the long run.
Unfortunately, I haven’t found a way to prevent this in Audacity’s settings.
Do you have any idea how I can change the software’s behavior?
I have attached the device info from Audacity, maybe it will provide a clue?
Thank you very much for your help.
deviceinfo.txt (6.1 KB)
