I’m seeking advice on automating the process of trimming the start of the last 10 seconds of multiple audio tracks and exporting them as separate tracks. I prefer using Audacity or a Python script for this task.
To clarify, I don’t want to remove the last 10 seconds entirely; instead, I aim to create separate segments starting from the last 10 seconds of each track and export them individually.
Here’s what I’d like to accomplish:
- Import multiple audio files into Audacity or another suitable tool.
- Automatically select and trim the portion from the start of each track, leaving only the last 10 seconds as a separate segment.
- Export each trimmed segment as a separate audio track file.
I just want to split the last 10 seconds automatically because I don’t want to do it manually for 96 tracks.
