Hi everyone,
So i’m doing voiceover for podcasts and I was wondering if there’s any way I can improve my current workflow :
- I split the part on which i’m will do the voiceover into its own section
- I use the enveloppe tool to fade out the beginning of the section, then fade in the end, all manually, which make it difficult to stay consistent in terms of decibels across the whole podcast.
Here’s a screenshot : https://ibb.co/y4xBP4x
Is there any way I can turn this into a macro / use a built-in effect to speed up the process and have a consistent level / duration of fades ?
Thanks !
Windows 11 / Audacity 3.1.3
