Automatic recovery of unsaved file .aup3unsaved doesn't work
I am new to Audacity, so please bear with me. I did a three-hour recording with my grandma about her life. Everything went well. At the end, I wanted to save the project, but Audacity crashed.
Right after the crash, I luckily copied three files from the “SessionData” folder, just in case. These are the files:
***.aup3unsaved 3,7 gb
***.aup3unsaved-shm 32 kb
***.aup3unsaved-wal 2,7 mb
When restarting the app, it says that the recovery process starts. Unfortunately, nothing happens. I just get an empty dashboard (at the top left, where usually the file name appears it just says “(recovered)”.
I also renamed the files (deleting “unsaved” from the file extension). I got the same result as with the recovery process. It says that it is unsaved work that is being recovered, but it doesn’t become visible as a track.
I spent quite a bit of time today searching through this forum. I understand that @jademan has helped people recover files but doesn’t do that anymore.
Given the file size, some data should be there, right?
What are the things I could try? Are there any great resources I could check? Anyone else had this problem?
Recovering this file really means a lot to me!!!
Any tips are highly appreciated.
Thank you! :pray::pray::pray:
Any help or hints would be greatly appreciated!! Thank you!
So for whatever reason I have never had luck recovering unrecoverable .aup3unsaved files.
If I am recording directly into Audacity I now first create an empty project then save it. I open the empty project and record into it. I have had better luck this way.
For even more reliable recordings, use a dedicated device (I use an H2n) or even your phone (Voice Recorder on iphone).
Thanks for your response. So the data is permanently lost then!? That really sucks. :sob: :sob: :sob:
iPhone > Settings > Voice Memos > Audio Quality > Lossless.
