Is it possible for Audacity either by default or with a plugin/extension to scan an audio file for silence markers, audience clap, or other distinguishable marks to “automatically” split an entire live concert audio file and then export each individual track automatically?
I used to use a wave splitter tool that automatically found the gaps, or if it was off, you could adjust sliders to cut at the appropriate mark. Then it would export the large audio file into individual tracks.
How would I do this using audacity?
Thank you.
