Hello,
I have like 200 multi-sample wav files. I would like to separate each sample into one-shot sample wav file.
I put 50 wav files in audacity, each in its own track, and was able to “separate” them by using “detach at silence”.
Then I would like to have each sample in its own track, to execute another command. Or, I could also export every sample to their own file, and then re-import everything.
But I’m stuck. I tried labeling but as far as I understand it’s not compatible with my multi-track case. I quickly look into macros to change my approach but was not able to either spit to new track by label or to export multiple.
Here is an image to illustrate where I’m struck, i would like each snippet of sound to be its own file (and keep the name of the original file with a prefix/suffix)
I’m looking for mostly automated process as I have a lot of file.
Thank you for taking the time to read ![]()
MacOS 13.4 / Audacity 3.6.4
