.aup file won't open
I moved my .aup file out of the data folder and now it won’t open even though I moved it back. How can I resolve this?
You also need the similarly named “_data” folder. It needs to reside in the same directory as the .aup file. The .aup file is usually not in the _data folder, but separate.
Hi and thanks for your response. How do I locate the directory? I’m using a Mac.
Nevermind. I was able to resolve it.
