Audio sample changes
When Audacity does a new update I need them.to bring back the audio sample bit. So I know if it’s 44hz or 48hz I’m working with.
As a work-around you can install an older verson or check your files with MediaInfoOnline or you can download and install MediaInfo on your computer.
The sample rate can be found in the track dropdown window.
