The audio jack works fine, but in Audacity, I plug in my headphones, but the sound still goes through the speakers. I’ve searched for a solution, not finding one
How do I solve this so that when I listen to audacity, I can listen through my headphones?
I had a similar problem on my Windows 10 PC. I solved it through free open source “AudioSwitch” (https://github.com/sirWest/AudioSwitch), which allows you to “switch between default audio input or output + change volume”.
If when you plug in the headphones you hear sound in the speakers and headphones, this could be a setting in your sound card. Hold Windows key down, press X and choose “Control Panel” then look under “Hardware and Sound” for your sound card’s control panel.
It doesn’t appear to be. If I listen to other programs or audio, sounds go to the earphones. But not with audacity. According to the settings, the jack is working properly.
You don’t need it, but setting and resetting the default audio output in Windows 10 as I had to do was hell. It was convoluted and cumbersome. It involved plenty of clicks. It had to be repeated over and over again. With “AudioSwitch” (https://github.com/sirWest/AudioSwitch), it only takes 2 clicks to switch between speakers and headphones, and back if necessary. AudioSwitch is a safe harmless application. If it does not work or does not suit your needs, you can easily uninstall it. It is running fine in Windows 10 x64.
Sorry! My bad! I had never paid any attention to the upward-facing arrow on the right of the current audio playback device. It does give access to a list of all enabled audio playback devices. I am going to uninstall AudioSwitch.
I tried to download AudioSwitch and it isn’t free. I’m taken to a page to “donate” and as much as I’d love to donate, it’s asking me to pay in Euros. So really, it’s a dead end.
Moderator note: For security reasons, please do not link directly to executable files. I have replace the link to “AudioSwitchSetup.2.1.5.0.exe” (above) with text. If anyone wants to use the link, they can copy the address into their web browser address bar. Please note that for safety, EVERYTHING downloaded from the Internet should be scanned for malware / viruses. A good on-line malware / virus checker is: https://www.virustotal.com.
