Hi have been using audacity to record old vinyls to computer for a while, basically i have a vynil record player with USB connectivity.
So i open Audacity and can record directly form the Vinyl to WAV using the record player USB connectivity.
Now i have acquired a new laptop, a dell alienware aurora 16, and i have done the same configuration i have been using.
First i go to Transport > Transport Options > Enable audible input monitoring.
Then in audio setup, playback device i choose speakers realtek audio.
Audio setup, recordig device i choose my usb CODEC device (turntable).
Finally i activate the “Silent Monitoring” on the Record Meter.
But when i put a record on play on the turntable the sound is terrible and the meters reach only half of the way, but sounds terrible…
What should i check, change on my new laptop to get good qualitiy output? has anybody else experinced this beofre, this only happends wh my dell alienware autora as i went back to my old machine and setted up everything just the same and it works fine.
using audacity 3.7.5 on windows 11
thank you.
