So I’m recording a rap song on my computer and the audio is distorted. I’m over dubbing over a track with really heavy bass. When the track it quiet, like in a lull in the beat, my audio is really loud, but when the track is loud with high bass and stuff, my audio is really quiet. Using a p120 compression microphone
Yes I meant AKG P120. And this didn’t work, also when I export it and listen on a different computer it still does this. And when I lower the gain it goes away kinda but it’s obviously just really quiet, I want a way to fix this without having to change the gain
Did you ever find a cause for this over the past few years? I have the same exact issue (with sound being quieter in the middle of the recording) only I am recording a live instrument and using Linux. I’ll post a separate thread but if someone has come across the cause like a setting I’d like to find out what it is. As an example for a setting-caused issue, one of my first issues ended up being caused by the sound-activated recording setting, which causes it to stop when it encounters a certain level of ‘silence’.
