Audio gets muted when I opened Audacity -help
I downloaded Audacity and when I open it my audio its muted. Even after I close it, its still muted and the only way to get back working again is when I restart my PC. I also tried to do an audio recording and it doesn’t pick up my mic but Windows audio recorder does. I did change it to the proper mic settings.
Anyone know how to fix this? I tried unistalling and reinstalling and I still get the same issue. Could someone help me fix this please? Thanks
If you are using a USB mic (or any other USB audio device), see here: https://manual.audacityteam.org/man/faq_playback.html#usb
I’m not. I’m using the speakers output from the back of my pc. I use a cable that connects the mic and audio and then on the other end connect it to my bose qc20 earphones that has a mic. My mic still gets picked up because I can see the waves moving but my audio is completely lost all the time. Been reinstalling like 6 times, even tried the deve version still have this issue.
Is that the mic that you are recording with, or are you recording with a different mic?
Do they require special drivers on Windows?
The bose website says:
These headphones are designed for iPhone, iPad and iPod models. They are not compatible with iPhone 7 and later. A Lightning to 3.5-mm adapter is needed for iPhone 7 and later. A version is also available for Samsung and Android devices.
What sort of cable is that? Where does it plug into your computer?
We don’t publish a dev version :confused:
No they don’t the mic works, Ive tested it. Its just when I open audacity everything get muted. But I can the waveforms. Its just a headphone splitter
https://www.amazon.ca/Headphone-Splitter-KOOPAO-Microphone-Earphones/dp/B087CZB5RL/ref=sr_1_16?crid=BO9IRRGSEMX6&dchild=1&keywords=cable+splitter+headphone+jack&qid=1600400554&sprefix=cable+spliter%2Caps%2C147&sr=8-16
Its audacity-win-2.4.2rc01 forgot what its called. I tried the regular version aswell. I get the same issue. :confused:
