Audio file compleltly flat and silent
Hi there yall,
I came back to an audio file is was working on that was not saved correctly.
One of the audio tracks is completely flat a silent. I think the issue is with a noise gate that was added.
I am unable to undo the noise gate (or at least do not know how).
I am also unable to find the original and just start over. otherwise i would have done that already.
Photo below the problem audio track is the bottom one labelled Phil.
Any advice is appreciated as it stands now i will have to scrap the whole project unless i can fix that track.
If it was saved like that (silent) and closed there’s no reversing it.
A noise-gate can silence a track, but so can corruption of the Audacity project.
If you’re using cloud storage, (e.g. OneDrive), whilst editing, that can fail to save projects correctly.
Thats a bummer, oh well live and learn. thank you sir
