Hello!
We’ve added embed support for audio.com embeds in the forum (and any other forum using the discourse forum software)!
To use them, simply put an audio.com link in a new line, and it’ll show an embed like this:
You can upload your files directly to audio.com from within Audacity via the Share Audio button. More info: Sharing audio online - Audacity Support
Trebor
3
Customer support ?, if so I’d like to report that its search is funked-up …
ah, no - support for embedding sounds from there in the forum. I’ve updated the post to clarify that.
Regarding your feedback, you may want to shoot them an email at [email protected] with this.
Trebor
5
Pro-tip: if you blur part of the image it makes the waveform easier to see
