Audio channels look different
I am recording in two different channels and in previous versions of Audacity, both channels looked the same. Now they look different and there is a lot of drag and drop that I accidentally press. If you look in the image I added, you see that the color coding is different. The thick lines on the top view get more and more narrow as time passes. Does that change the sound?
Multi-tool has been selected … Multi-Tool - Audacity Manual
Thank you! How do I remove that?
Click on the I-beam button …
https://manual.audacityteam.org/man/tools_toolbar.html
Thank you so much! Now I just wonder how I change the top channel so that it “is light blue” all the way. When I try to grab it I get a “forbidden” icon.
I am just doing simple cutting (removing small parts here and there) yet still it changes form. Now it looks like this! :
Fixed it! Not my favourite part of Audacity.
