Audio Capture from Tape issues
Hey folks. New user here so do forgive me if I come across as a little naive.
Ive bought an Ezcap Cassette player, and a Digitnow USB audio capture card. Ive installed Audacity, and now want to capture my tape audio.
As I goto record a new wav file, I keep getting an error 9999 - Unanticipated host error. Any help would be amazing folks.
There seems to be more than one model of this device. Please specify.
Where does this .wav come from?
What is connected how to what?
What operating system (Name and version)?
Hi Mac-Christian.
The Ezcap model is FCC ID :2AYNG:EZCAP
I opened Audacity, selected file, new. Pressed the red record button, then that error appeared.
Check your Permissions/Privacy Settings for the USB device.
Error Codes:
Well, the FCC ID doesn’t tell me anything. See the image below - there are still more:
Since you didn’t answer my other questions, I am out here.
I did answer mate. The model number is Ezcap 215. Cheers
I do apologise, I didn’t see this part of your reply properly. Reading isn’t my strongest ability.
I’m using windows 10, the wav was created using Audition.
Tape player ----- External USB soundcard ----- laptop
