Using Audacity 3.7.1 for Windows 10 and Audio-technica AT-LP120-USB turntable with built in pre-amp, not able to monitor sound through speakers while recording although the Enable Audible Input Monitoring is selected. I’ve checked software and computer settings numerous times. Any ideas what I’m missing? Thanks!
Check your Playback Device.
Windows may have switched the default to the “new” USB device and it might be trying to play through the turntable.
Or in case you don’t know, the playback (and monitoring) volume slider is now “hidden” behind the playback meters.
