Un saludo a todos. Es mi primer post y quiero agradecer que me dejéis participar en el. Tengo Windows 10 (64b) y una mesa behringer xair xr18. Me gustaría poder grabar todos los canales posibles con el Audacity, pero no soy capaz de configurarla para grabar. Tengo algo de experiencia con este programa ya soy capaz de grabar con mi mesa behringer henix Q502USB. Tengo instalado el driver de la mesa y el PC la reconoce. Siempre sale el mismo error: " Error al abrir el dispositivo de grabación. Código de error: -9999 Unanticipated host error". gracias por vuestra atención.
I believe you will need to use ASIO to record the XR18 with audacity. See ASIO Audio Interface: https://manual.audacityteam.org/man/asio_audio_interface.html
Gracias por la respuesta. Tengo instalado el driver ASIO para xr18.
Thanks for the reply. I have installed the ASIO driver for xr18.
OK, well, the driver was the easy part. You will need that to record 18 channels simultaneously from your XR18.
Now for the fun part!
Since there are open-source licensing issues, you will have to compile your own private version of audacity built with ASIO. ![]()
See:
https://manual.audacityteam.org/man/asio_audio_interface.html#:~:text=Non%2Ddistributable%20ASIO%20support%20in%20Audacity,-Audacity%20provides%20ASIO&text=ASIO%20support%20is%20provided%20strictly,(private%20or%20commercial)%20use.
(Note that when you do get this setup, be sure that your x-air setup audio/midi clock rate is the same as the audacity project rate.)
Also, Cakewalk is now free. See: http://www.cakewalk.com/
