I’m trying to use Audacity to digitize a collection of old Vinyl LPs. I’m running Audacity version 3.1.0 on MacOS 10.15.7 on a MacBook Pro.
The line out from my pre-amp is connected to an old Griffin iMic, and the USB from the iMic is connected to the MacBook. I’ve I set up Audacity’s “transport” section to use “Core Audio”, “iMic USB Audio System”, “Stereo Recording” and “Built-in Output” (which is my headphones). Nevertheless, when I press record, nothing happens; I see no waveform, the input level meters show nothing, and there is no sound on the headphones.
In contrast, using Quicktime Player and Garage Band, I can record audio from the iMic USB Audio System without any problem. I can then import this audio into Audacity, and edit it — the editing, including splitting tracks and pop removal, seems to work fine. But recording doesn’t work at all.
As an experiment, I’ve also tried recording form the built-in microphone. This also fails in Audacity (but works in Quicktime Player).
This was a new installation of Audacity. I’ve tried re-booting the MacBook. Soundflower is not installed — should it be? What am I doing wrong?
