Audacity won't play any actual sound [SOLVED]
So I’d been using Audacity 1.2.6 just fine for a while, when all the sudden, as I was adjusting the master volume within Audacity, the program just completely stopped playing sound, even though the bars at the top still made it look like sound was being played. Nothing I did got it to play sound again, and the playback device was set to “Speakers (Realtek High Definition Audio)” as it always had been. My speakers are still fine with all other applications. So I uninstalled and upgraded to Audacity 2.0.5, but the problem still persists. Any suggestions?
Try reinstalling Audacity 2.0.5 and select the “Reset Preferences” option during the installation. When the installation is complete and you launch Audacity, you will be prompted to confirm that you want to reset the preferences.
Tried it, problem persists
Which version of Windows?
Please select from the “Help” menu “Audio Device Info”, then copy and paste the contents into your reply.
Windows 7
Here’s the audio device info:
Default capture device number: -1
Default playback device number: 1
Device ID: 0
Device name: Microsoft Sound Mapper - Output
Host name: MME
Input channels: 0
Output channels: 2
Low Input Latency: 0.090000
Low Output Latency: 0.090000
High Input Latency: 0.180000
High Output Latency: 0.180000
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 1
Device name: Speakers (Realtek High Definiti
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 2
Device name: Realtek Digital Output (Realtek
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 3
Device name: Realtek Digital Output(Optical)
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 4
Device name: Primary Sound Driver
Host name: Windows DirectSound
Input channels: 0
Output channels: 2
Low Input Latency: 0.000000
Low Output Latency: 0.120000
High Input Latency: 0.000000
High Output Latency: 0.240000
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 5
Device name: Speakers (Realtek High Definition Audio)
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 6
Device name: Realtek Digital Output (Realtek High Definition Audio)
Input channels: 0
Output channels: 6
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 7
Device name: Realtek Digital Output(Optical) (Realtek High Definition Audio)
Input channels: 0
Output channels: 6
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 8
Host name: Windows WASAPI
Input channels: 0
Output channels: 2
Low Output Latency: 0.003000
High Output Latency: 0.010000
Supported Rates:
    48000
Device ID: 9
Device name: Realtek Digital Output (Realtek High Definition Audio) (loopback)
Input channels: 2
Output channels: 0
Low Input Latency: 0.003000
Low Output Latency: 0.000000
High Input Latency: 0.010000
High Output Latency: 0.000000
Supported Rates:
Device ID: 10
Input channels: 0
Output channels: 2
High Output Latency: 0.010159
Supported Rates:
    44100
Device ID: 11
Device name: Speakers (Realtek High Definition Audio) (loopback)
Input channels: 2
Output channels: 0
High Input Latency: 0.010159
Supported Rates:
Device ID: 12
Input channels: 0
Output channels: 2
Supported Rates:
    48000
Device ID: 13
Device name: Realtek Digital Output(Optical) (Realtek High Definition Audio) (loopback)
Input channels: 2
Output channels: 0
Supported Rates:
Selected capture device: 9 - Realtek Digital Output (Realtek High Definition Audio) (loopback)
Selected playback device: 1 - Speakers (Realtek High Definiti
Supported Rates:
    48000
Recieved -9996 while opening devices
Currently you have no input devices available other than the WASAPI loopback devices.
Go into the Windows Sound Control Panel and enable a recording device. There may be one or more listed as “mic” or “line” for “Realtek High Definition” or something similar. Probably hidden and disabled, so see the link for how to make devices visible and enabled.
In the “Host” box of the device toolbar, select “MME”.
Then you will need to set the recording device (in the device toolbar) to match the recording device that you enabled in the Windows Sound Control Panel.
My computer doesn’t have a built in mic, but plugging in a microphone and setting the recording device works fine. However, Audacity still isn’t outputting any sound, so I have to export and use a media player to hear what I just recorded/generated/editted.
OK, with your set-up now, and with the mic connected, and “Host” set to MME, could you do the “Device Info” thing again and post the contents.
If the green playback cursor and the meter bars are moving when you try to play audio in Audacity I don’t think this is a devices problem.
Are you sure all your Audacity tracks are unmuted?
Play some audio in Audacity. Left-click the speaker icon by the system clock, and choose “Mixer”. Make sure the slider for Audacity is unmuted and turned up.
Have you tried shutting down the computer then starting it again?
So it turned out Audacity somehow got muted in the mixer, which I don’t believe I’ve ever actually opened before. Weird, but it works now. Thanks and sorry for not checking that earlier.
