If the extended virus scan clears you, then there’s nothing “normal” wrong. The Audacity developers may want to chat with you.
There is a new Audacity version (3.0.3) coming out shortly.
When you are exporting (or saving), do you get the opportunity to enter a filename? There are rules for names. Upper Case Letters, lower case letters and numbers are OK. -Dash- and underscore are the only two valid punctuation marks.
Use ISO dates. Today is 2021-07-02.
You get no error messages at all?
One more Mac-ism.
You downloaded the audacity-macos-3.0.2.dmg file, right? Double click it and it will display an installer graphic.
Drag the Audacity.app Picture to the Applications Picture.
It’s possible to miss this step and be running a Partial Audacity. A Partial install will not be able to access the drives.
The virus scan came back clear it didn’t detect any viruses. When I try to export it doesn’t give me the opportunity to enter a filename at all nothing like that pops up on the screen. And I get no error messages at all. And I did download the audacity-macos-3.0.2.dmg file and did exactly as the installer instructed.
Just checking that we’re all on the same page:
When you select “File menu > Export >”
Are the Export options greyed out?
When you click on “File menu > Export > Export as WAV”
“Absolutely nothing” happens? You don’t see this screen?
When I select File menu > Export > all the export options are there. They are not greyed out. Also when I select File menu > Export > nothing happens at all. I do not see that screen at all
Have you tried resetting Audacity? (“Tools menu > Reset Configuration”)
no, I haven’t. if I do that will it erase the audio I have in there now?
It shouldn’t, but given that there’s something very weird going on, I wouldn’t make any guarantees.
I assume that “Save Project” does nothing as well? If you can save the project first, do so. Otherwise, I think you have nothing to lose because currently there’s no way to get the audio out of Audacity.
I did the reset configuration and tried to export again but still having the same issue. I might just have to try to uninstall/reinstall audacity and see if that works
Re-installing Audacity will not help.
Click on Audacity (menu) > Preferences, then “Directories” in the list on the left. What do you see?
– Bill
hi, I reinstalled it its working now. Thanks for all your help
That should not make any difference. No changes are made to the Audacity application once it is installed. The way to completely reset Audacity is to delete the audacity.cfg file located in ~/Library/Application Support/audacity.
Do you remember where you downloaded Audacity from originally, and where you got the “new” one?
– Bill
We covered that up the thread.
Let me read that back to you. Your installation of Audacity has a 50% success rate for no reason we’ve been able to find—and it only happens to your machine.
Don’t do anything critical.
I am having exactly this same issue as well
And you tried reinstalling ?
