I downloaded Freeverb3 singpleprecision from the official freeverb3 website.
http://freeverb3vst.osdn.jp/downloads.shtml
Then, I extracted the file and put all of the .dll and .XML files in the audacity plug-ins folder.
When I opened audacity I couldn’t find them in the effects bar, do I clicked on “Manage”.
I saw my freeverb files and I enabled the Freeverb3VST_Impulser2, since I only need that file. It’s state went from “new” to “enabled”.
I clicked ok.
When I opened the effects folder again, there was no freeverb3 plug-in - there were just the old ones. Then I clicked on “Manage” and the file’s state was again on “New”.
I set it again to “Enable”.
I did this many times, I restarted audacity, I made sure all of the files were downloaded correctly and put into the right folder and I really don’t know what’s wrong.
Help!? ![]()
