Audacity Warning: Critical Nyquist
Every time I open Audacity I get the following warning:
“Critical Nyquist files could not be found. Nyquist effects will not work.”
How do I get those files, thus solving the bother of having to close that window every time?
I run audacity on a MacBook Pro (2012) and have the latest version (2.0.6 for Mac).
Thank you for your help,
AkitaInu1994
You need to install Audacity correctly, as described here: https://forum.audacityteam.org/t/installation-do-not-run-audacity-from-the-dmg/31711/1
