Hi
Using the microphone to record is fine. I can set to log anything above a certain db which can then send as an excel file.
However, is there any way to have anything set above a certain db straight away to excel in real time?
Thanks
Hi
Thanks
You can do what?
Perhaps you could describe what you mean using more words.
Hi Steve
i can transfer data to excel after working on a sound.
Is there any way to transfer to excel in real time
Example
Let’s say I’m watching a YouTube video of a guy doing a basic drum beat. I will want to transfer to excel any noise above a certain db - in this case, trying to capture each time the drummer hits the cymbals. If it’s a 30 second video, when transferred to excel I should hopefully see when exactly the cymbals were hit (noise set to certain db level) so let’s say 5 13 18 26 seconds.
Which is great. But I’d like to transfer the data to excel in real time rather than wait until the video is finished, then transfer to excel
Hope that’s a bit clearer
I think the answer is probably no you can’t do that in real time, though I still don’t understand what you mean by “transfer data to excel”. How are you doing that? Are you talking about Sample Data Export?
Yes sample data export.
I can use that for logging data but real time is needed.
Thanks
Sorry no luck. It doesn’t do real time.
