Audacity suddenly bad recording
Hi. I’ve seen a few posts mentioning bad quality recordings - with some suggestions, but none seem to answer my problem. I have been using Audacity for many years - love it. But, today, my project had a terrible recording quality - like it had been recorded from an old transistor radio (remember those?).
I’m recording from YouTube - as I usually do - in order to edit music for my annual firework display. But I can’t possibly use the recordings from today.
I’ve tried boosting the bass & reducing the treble, but it isn’t right & the sound is still “thin & hollow” - like I said - as if I were listening to a small transistor radio. It’s the same if I record from Spotify etc.
When I play last year’s, or previous year’s projects, they play great with a rich full sound.
What can suddenly be the matter ? What can I do please? Thank you so much.
It sounds like maybe you are recording from the microphone built-into your laptop.
Tutorial - Recording Computer Playback on Windows
Hi. No it’s not that. All the settings seem ok. I’ve been 10 days now fiddling around with bass, treble, whatever, whatever, whatever. But it’s still a lower volume & very “thin” - there’s no full rich sound like my previous recordings. Amplifying doesn’t help - just makes it louder & more horrible. The blue wave has thin vertical lines - not deep bold lines like my previous projects. I’m panicking now because I have a deadline for this project ! There’s no point messing around with it any longer - it’s DEFINITELY in the recording & so I’ll have to do it all again. Thanks anyway.
Do a brief test to make sure doing it over again is going to work.
