Hi,
I’ve been using and recommending Audacity for a number of years, now (Ver 1.something.or.other).
Just bought an Alesis MultiMix 4 USB mixer/audio interface a week ago and had it working without much hassle in Audacity 2.0.2.
Today, I tried to get an audio connection to the Alesis mixer from within Live 9 Lite, and didn’t have much luck.
Now, I can’t record with Audacity.
Updated to Audacity 2.0.5 today, using the .exe installer.
Win 7 Pro, SP 1, 32-bit install
AMD Athlon 64 X2 Dual Core Processor 4000+ 2.10GHz
4 GB RAM installed, 3.62 GB usable
Audacity settings:
Audio Host = Windows Direct Sound
Output Device = Speakers (Realtek High Definition Audio)
Input Device:
- Primary Sound Capture Driver - worked until earlier today - Now, tries to record, but flat line.
- Stereo Mix (Realtek High Definition Audio) - Tries to record, but flat line.
- Microphone (USB Audio CODEC) - Error while opening sound device. Please check the input device settings and the project sample rate.
Input Channels: 2 (Stereo) Input Channels
Project sample rate = 44100
System sound settings:
Playback devices
Speakers, Realtek High Definition Audio = Default device
All Enhancements off
Advanced tab: 24 bit, 44100 Hz (Studio Quality); both Exclusive Mode boxes checked
Speakers, USB Audio CODEC = Ready
Advanced tab: 16 bit, 44100 Hz (CD Quality); both Exclusive Mode boxes checked
Recording devices
Stereo Mix, Realtek High Definition Audio = Default device
Levels tab: Stereo Mix = 49
Enhancements tab: only “DC Offset Cancellation” checked
Advanced tab: 2 channel, 16 bit, 44100 Hz (CD Quality); both Exclusive Mode boxes checked
Microphone, USB Audio CODEC = Ready
Levels = 49
Alesis Multimix 4 USB settings:
Sennheiser e825 mic
Known good XLR mic cable (at least it was working yesterday)
Channel 1
- Gain: 11:00
- EQ: flat
- Pan: centered
- Level 1: 12:00
Main VOL: 11:30
USB cable connected to computer, which registers when either end is connected/disconnected.
Mixer is powered on.
Main Level registers between -12 and 0 dB
Hope that’s enough information.
