Audacity | Split | duplicate split-positions [SOLVED]
Audacity_2.1.2
win10_Home_x64
AUDACITY
  • How to do a split
  • Edit → Clip-Boundaries → Split
  • depending on whether it’s a point vs. selection
  • CTRL-I
  • Point vs. Selection
  • Point
  • A point will only be to where the cursor is placed and there isn’t more than 1-cursor
  • Selection
  • To your current selection both the beginning-point & ending-point will be marked as splitted
DILEMMA
  • I want to be able to do the same split formatting to multiple tracks that are the same.
  • This is an extremely tedious process if the split-amount is like about 500-sectors.
EXAMPLE
https://s15.postimg.org/53tvm9fdn/Capture.jpg
NOTE
  • Having the ability to duplicate split-points from one layer to another will be more helpful with a keybind keyboard shortcut hotkey.
Create “labels” at the places where you want splits to occur, then select the label track plus all of the tracks that you want to split, and apply “Edit > Labelled audio > Split”.
See: Edit Menu: Labeled Audio - Audacity Manual
[SOLVED] Thanks, Big-up, Safe, This help me fix the problem, Thank-You very much. :smiley:
SUMMARY
  • For each section you want to split
  • Start off by creating labels to represent each split
  • then, select the whole label track-layer + the original track-layer(s)
    you want to split
  • Edit → Labeled Audio → Split
  • Alt+I
