Hi,
audacity revision 12379 (Simplify Leveller dialog) fails to build on Ubuntu Maverick 10.10. Revision 12378 builds fine. The build stops at:
g++ -c -I…/lib-src/portmixer/include -Wall -I/usr/lib/wx/include/gtk2-unicode-release-2.8 -I/usr/include/wx-2.8 -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXGTK__ -pthread -I…/lib-src/FileDialog -I/root/audacity-read-only/lib-src/lib-widget-extra -I…/lib-src/libsndfile/src -I…/lib-src/libsoxr/src -I…/lib-src/sbsms/include -I/usr/include/soundtouch -I…/lib-src/libnyquist -I…/lib-src/portsmf -I…/lib-src/portaudio-v19/include -fno-strict-aliasing -I./include -I. -DLIBDIR=“/usr/lib” -D__STDC_CONSTANT_MACROS -Wall -pthread -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/libpng12 effects/Leveller.cpp -o effects/Leveller.o
/usr/include/wx-2.8/wx/string.h: In member function ‘virtual void LevellerDialog::PopulateOrExchange(ShuttleGui&)’:
/usr/include/wx-2.8/wx/string.h:682: error: ‘wxString::wxString(int)’ is private
effects/Leveller.cpp:225: error: within this context
effects/Leveller.cpp:233: error: within this context
make[1]: *** [effects/Leveller.o] Error 1
Hope this helps.
Regards.
