Audacity pour Mac OS sequoia 15
Bonjour,
I can’t install audacity for Mac OS sequoia 15. Does it exist ? how can I do ?
huge thanks
Florence
Je n’arrive pas à installer Audacity et suis peu agile en informatique, est-ce qu’àudacity existe pour Mac OS séquoia 15 ? si oui, est-ce que qu’un m’aiderait à l’installer ?
Merci
Belle journée
Florence
I have installed Audacity 3.6.4 on macOS 15.0.1 with no problem.
J’ai installé Audacity 3.6.4 sur macOS 15.0.1 sans problème.
I installed Audacity on Mac OS 15.0.1 but cannot get my Blue Yeti mic to record. Has anyone had this problem?
Does Audacity have permission to use the “microphone”?
Yes. It does. Everything is set up as it should, but I cannot record.
Check the recording meter. The recording level control is part of the meter and it is easy to set it to zero without noticing.
