Hello! I normally use Audacity on my pc but want to use it on my Mac, on occasion, for VO when I’m on the road. I did my best to copy the same settings into the Mac application as for the pc app but are there specific settings I should be aware of for the MacBook?
Thanks!
What specific settings do you refer to?
Audacity’s settings are the same on all platform, if you use the same version of Audacity.
Thank you Mac-christian. I think I understand. I’m pretty sure I’ve got it set up the way I want it on the Mac.
If you recently installed Audacity on the Mac and did not use it before, please go to System Settings (under the Apple menu) → Security and Privacy → Microphone and grant access to Audacity. The image is from macOS 12.7.6 “Monterey”; it looks different under macOS 14.x “Sonoma”.
