I updated a few days ago 1909 windows update. SInce then audacity 2.3.3 does not work. Specifically I cannnot record. I can import music and manipulate it but when I hit the record button nothing happens. It just crashes every single time.
I have to this date done
diagnostic check of the computer, we are good there
uninstalled and reinstalled audacity 2.3.3 no change
updated realtek driver
checked for viruses and malware good there
Contacted microsoft…no help at all
Have others had problems in general after this update? Has is, or how has it affected audacity?
Any help is appreciated and very welcome
Best,
I have not updated to 1909. So I can’t comment on that. But sadly sometimes,the so called patches are problematic. Can you roll the version back. Restore point hopefully will help.
I’ve just tested with 1909 Windows x64 10 Prof. using an ordinary microphone but I can’t reproduce the problem you describe. However this is on a desktop Core i7 with Realtek drivers. I would start by looking at your recording devices under the mmsys.cpl control panel to see if you are getting a signal on the level meter.
Sorry I have been away for so long…
Yes I went into device manager and it says the mic is working properly
I went into driver and update, and it says I have the latest one.
I have gone into control panel into sound, everything seems fine there.
I went into sound recognition and it is picking up my mic.
I don’t get it when I hit record on Audacity it crashes.
