Audacity Not Playing Through Headphones
Out of nowhere I’m having an issue where Audacity isn’t playing audio through my headphones. Before anyone replies with the standard fixes:
-I DO have the latest update
-I’ve double checked and my output devices ARE correct
-I’ve restarted
-I’ve reinstalled
-It works on other recording software
Do you know that the playback (and monitoring) volume slider is now “hidden” under the playback meters?
Do the speakers work?
Are you on Windows?
I assume you see a waveform?
Are the playback meters showing activity?
Yes, when recording everything works perfectly except the playback which SAYS my headphones are the output
