Audacity-mcp (control Audacity with natural language w/ Claude)
Hi all,
This is my first post here. I recently built a small open-source tool called audacity-mcp that I thought might interest this community. I didn’t see anything like it out there and I thought it might be useful to somebody.
It’s a Model Context Protocol server that lets Claude (Anthropic’s AI assistant) control Audacity through natural language using the mod-script-pipe interface that Audacity already exposes. No new internals touched.
You can say things like:
  • “Normalize all tracks to -1 dB, then export as FLAC”
  • “Select from 2 to 8 seconds and apply fade in”
  • “Add a label at 12.5 seconds called ‘bridge’”
  • “Apply my CleanPodcast macro to the current selection”
It supports normalize, amplify, fade in/out, noise reduction (two-pass), macros, export/import (WAV/FLAC/MP3/AIFF/OGG), labels, and transport controls. Works on macOS, Linux, and Windows.
The code is MIT-licensed and on GitHub: https://github.com/tachyonshuggy/audacity-mcp
It’s newly released and I’ve tested it against the mod-script-pipe spec, but not across every Audacity version.
Feedback and issue reports are very welcome. Happy to answer questions here or on the repo.
  • tachyonshuggy
Can it be made to clean my LPs then digitise them and file them away so I don’t have to face doing it? Joking aside, it sounds like a great tool.
I am using claude code I may be able to vibe code something let me know
