Audacity macros are not working properly (is it a bug?)
I wanted to use a macro by doing the following, but it doesn’t work properly. Is this a bug?
  1. Create a new macro name with “Normalize to Amplify”.
  2. Register “Select All” → “Normalize” → “Amplify” → “End” as the macro content.
  3. Register the created macro to the F5 key on your keyboard.
  4. Restart Audacity and drop the audio file you want to edit.
  5. Press the F5 key. → At first glance, it appears to be working correctly.
  6. The last macro operation is “Amplify”, so if you want to amplify it a little more, press Ctrl+R, but it will not be amplified.
Isn’t this behavior (6) a bug in the program?
By the way, if you manually select “Select All” → “Normalize” → “Amplify” from the state where it is not “amplified” with Ctrl+R, you will be able to “amplify” (multiple times) with Ctrl+R.
After that, you can also change the audio file you want to edit (to a different file) and press the F5 key to “amplify” it using Ctrl+R. In other words, manual intervention is only required the first time after starting Audacity.
Isn’t this because macro operation commands are not recognized (or registered) as manually operated commands? If so, I think this is an obvious bug.
Please let me know if there is a workaround. If there is no workaround, I would like to ask you to modify the program.
Thank you very much for your support.
