Audacity is selecting multiple tracks. I mean, if I select track 2, even track 1 gets selected and edited at the same time!?
Drag and Drop is also NOT WORKING!
If I open the audio file, a new window of Audacity Editor opens to each number of audio files!!!
What the hell is going on I don’t understand! The same is the case with both Audacity Audio Editors, RDFE423F v2.2.0 Alpha and v2.3.1 Alpha-14fe11f.
Don’t use alpha versions of software unless you are an expert.
The current version of Audacity for Windows / macOS is Audacity 2.3.0 and is available via the Audacity website: https://www.audacityteam.org/download/
I have the same problem. Using an older version I would select a section of one track and automatically the same selection area would be selected in all of the other tracks. When I past into a track, it affects all of the other tracks. I loaded the most recent version and I still have the same problem.
I answered my own question. In the TRACKS pull down list at the bottom is a box to UNCHECK that is labeled KEEP TRACKS SYNCHRONIZED
