Hello fine people. This issue has been driving me nuts for awhile now and if anyone has the solution I will be eternally grateful. I want to use Audacity to remove background noise for YT videos and I know how to do that. Seems to work pretty well. The problem is, when I upload the original MP4 to Audacity and compare the length of the file to the original, it’s been stretched by about a second per hour. This is amazingly small but for play by play and reactions it makes things really off.
So for one video, Shotcut gives me a more precise length of video at 1:13:25:17. Audacity uses a decimal for its less than seconds unit (is that milliseconds?) and the file is 1:13:26.165. Why on earth is this happening and how can I fix it? I tried uninstalling and reinstalling. And I’ve tried working around by shrinking the file back to its original size by Audacity won’t reduce to the length of time I tell it to. Its often a bit off.
Any help you can provide is greatly appreciated. Oh! 2.2.2 on Windows 7.
