I have 300+ tracks to edit for an important wedding that is hosting 200+ guests
and Audacity is crashing and when it does work is lags and it lags bad.
I am trying all platforms and web pages to get help… so far I am not getting
any feedback… none, zero
I assume that you are currently using the latest version of Audacity.
Try going back to version 3.1, but before you do:
Any projects that you currently have on the go, either complete them first if you can, or save a backup copy AND export your current audio as WAV files to ensure you don’t lose your audio,
Backup any plug-ins that you rely on.
Uninstall Audacity, and delete the folder that holds the Audacity Preferences. The location of that folder depends on your operating system:
Also, you probably won’t need 300+ tracks for the wedding. As an estimate, 3 mins per track = 20 tracks per hour. After a couple of hours, no-one will care (or probably not even remember) if a track has been played before. Just ensure that you have a reasonable selection, and group them so that you can pick some appropriate tracks.
