audacity error opening sound device try changing audio host, playback device and the project sample rate [linux ubuntu]
Please state:
which version of Linux you are using,
the exact three-section version number of Audacity from Help menu > About Audacity,
whether you installed your distribution’s release, PPA version, or compiled Audacity from source code.
What settings are you using in the Device Toolbar?
UBUNTU 20.04 LTS
Audacity 3.1.0
my distribution is the latest one
dartsim-ubuntu-ppa-focal.list
dartsim-ubuntu-ppa-focal.list.save
sudo snap install audacity
These are playback devices list:
Default recording device number: 5
Default playback device number: 1
Device ID: 0
Device name: HDA Intel PCH: 92HD81B1X5 Analog (hw:0,0)
Host name: ALSA
Recording channels: 2
Playback channels: 0
Low Recording Latency: 0.00870748
Low Playback Latency: -1
High Recording Latency: 0.0348299
High Playback Latency: -1
Supported Rates:
Device ID: 1
Device name: HDA Intel PCH: HDMI 0 (hw:0,3)
Host name: ALSA
Recording channels: 0
Playback channels: 8
Low Recording Latency: -1
Low Playback Latency: 0.00870748
High Recording Latency: -1
High Playback Latency: 0.0348299
Supported Rates:
Device ID: 2
Device name: HDA Intel PCH: HDMI 1 (hw:0,7)
Host name: ALSA
Supported Rates:
Device ID: 3
Device name: sysdefault
Host name: ALSA
Recording channels: 128
Low Recording Latency: 0.0213333
High Recording Latency: 0.0213333
Supported Rates:
Device ID: 4
Device name: hdmi
Host name: ALSA
Supported Rates:
Device ID: 5
Device name: default
Host name: ALSA
Supported Rates:
Selected recording device: 5 - default
Selected playback device: 1 - HDA Intel PCH: HDMI 0 (hw:0,3)
Supported Rates:
The two ones work fine are [default & sysdefault] , but suddenly they disappear and the other three are left and I can’t find default and sysdefault in the choices anymore!
There should be a “Pulse” (PulseAudio) option.
(Please note that the Audacity team does not make the Snap package.)
What do you mean? what do you recommend?
The snap package is built by another group. The only format that Audacity provides (apart from source code) is the appimage (note this is an executable not an installer).
I haven’t tried the snap version myself but I’ve read that people have had issues with it. It would be a good idea to uninstall it and try the appimage.
The AppImage is available from the Audacity website: https://www.audacityteam.org/download/
So far no problems … thank you!
Thank you, Steve … it’s good so far!
