Earlier, Audacity showed me two windows, one above the other where there were showned the recording volume for each channel.
But when I opened it the other day, it showed nothing at all.
Whats wrong?
See if “recording meter toolbar” is ticked …
If you have Audcaity2 & Audacity3 on the same machine,
they can corrupt each other’s configuration if you do not keep them separate.
Yes, it is tipped
And I have only 3.2.5
Ticking “Reset toolbars” is the next thing to try …
https://manual.audacityteam.org/man/view_menu_toolbars.html
If that does not work try the more-radical “reset configuration” option …
https://manual.audacityteam.org/man/reset_configuration.html
Now, I deinstalled it and wanted to install it again, but I couldnt find it, but instead I found Wavepad and installed it, but that works fine!
But thank you for trying to help me!
