pactl list results in:
Module #0
Argument:
Usage counter: n/a
Properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "12.2"
Module #1
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore profile of cards"
Module #3
Argument:
Usage counter: n/a
Properties:
module.description = "Augment the property sets of streams with additional static information"
Module #4
Argument:
Usage counter: n/a
Properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available audio hardware and load matching drivers"
Module #6
Argument: device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1"
Usage counter: 1
Properties:
module.description = "ALSA Card"
Module #7
Argument: channels=2
Usage counter: n/a
Properties:
module.description = "Adds JACK sink/source ports when JACK is started"
Module #8
Argument:
Usage counter: n/a
Properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
Module #9
Argument:
Usage counter: n/a
Properties:
module.description = "ESOUND protocol (UNIX sockets)"
Module #10
Argument:
Usage counter: n/a
Properties:
module.description = "Native protocol (UNIX sockets)"
Module #11
Argument:
Usage counter: n/a
Properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
Module #12
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the default sink and source"
Module #13
Argument:
Usage counter: n/a
Properties:
module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
Module #14
Argument:
Usage counter: n/a
Properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #15
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically set device of streams based on intended roles of devices"
Module #16
Argument:
Usage counter: n/a
Properties:
module.description = "When a sink/source is idle for too long, suspend it"
Module #17
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each ConsoleKit session of this user"
Module #18
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each login session of this user"
Module #19
Argument:
Usage counter: n/a
Properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #20
Argument:
Usage counter: n/a
Properties:
module.description = "Mute & cork streams with certain roles while others exist"
Module #21
Argument:
Usage counter: n/a
Properties:
module.description = "Detect when various filters are desirable"
Module #22
Argument:
Usage counter: n/a
Properties:
module.description = "Load filter sinks automatically when needed"
Module #23
Argument: display=:0.0
Usage counter: n/a
Properties:
module.description = "X11 credential publisher"
Module #24
Argument: display=:0.0 session_manager=local/bzim:@/tmp/.ICE-unix/595,unix/bzim:/tmp/.ICE-unix/595
Usage counter: n/a
Properties:
module.description = "X11 session management"
Sink #0
State: RUNNING
Description: Built-in Audio Analog Stereo
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 44100Hz
Channel Map: front-left,front-right
Owner Module: 6
Mute: no
Volume: front-left: 16383 / 25% / -36.13 dB, front-right: 16383 / 25% / -36.13 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
Latency: 45875 usec, configured 46439 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC256 Analog"
alsa.id = "ALC256 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.card_name = "HDA Intel PCH"
alsa.long_card_name = "HDA Intel PCH at 0xf7320000 irq 130"
alsa.driver_name = "snd_hda_intel"
device.bus_path = "pci-0000:00:1f.3"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.vendor.name = "Intel Corporation"
device.product.id = "9d71"
device.product.name = "Sunrise Point-LP HD Audio"
device.form_factor = "internal"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
alsa.mixer_name = "Realtek ALC256"
alsa.components = "HDA:10ec0256,144dc796,00100002 HDA:8086280b,80860101,00100000"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
analog-output-speaker: Speakers (priority: 10000)
analog-output-headphones: Headphones (priority: 9000, not available)
Active Port: analog-output-speaker
Formats:
pcm
Source #0
State: IDLE
Description: Monitor of Built-in Audio Analog Stereo
Owner Module: 6
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Latency: 0 usec, configured 2000000 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Built-in Audio Analog Stereo"
device.class = "monitor"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
Formats:
pcm
Source #1
State: SUSPENDED
Owner Module: 6
Mute: no
Volume: front-left: 20316 / 31% / -30.52 dB, front-right: 20316 / 31% / -30.52 dB
balance 0.00
Base Volume: 6554 / 10% / -60.00 dB
Monitor of Sink: n/a
Latency: 0 usec, configured 0 usec
Properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
Ports:
analog-input-internal-mic: Internal Microphone (priority: 8900)
analog-input-mic: Microphone (priority: 8700, not available)
Active Port: analog-input-internal-mic
Formats:
pcm
Sink Input #2
Driver: protocol-native.c
Owner Module: 10
Client: 1
Sink: 0
Format: pcm, format.sample_format = "\"s16le\"" format.rate = "44100" format.channels = "2" format.channel_map = "\"front-left,front-right\""
Corked: no
Mute: no
balance 0.00
Buffer Latency: 0 usec
Sink Latency: 44935 usec
Resample method: n/a
Properties:
media.name = "ALSA Playback"
application.name = "ALSA plug-in [timidity]"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "32"
application.process.id = "528"
application.process.user = "bruno"
application.process.host = "bzim"
application.process.binary = "timidity"
application.language = "C"
application.process.machine_id = "1f99b08d281b44c5b0baaf6ce437303f"
module-stream-restore.id = "sink-input-by-application-name:ALSA plug-in [timidity]"
Client #0
Driver: module-systemd-login.c
Owner Module: 18
Properties:
application.name = "Login Session 2"
systemd-login.session = "2"
Client #1
Owner Module: 10
Properties:
Client #2
Owner Module: 10
Properties:
application.name = "xfwm4"
window.x11.display = ":0.0"
window.x11.screen = "0"
application.process.id = "606"
application.process.binary = "xfwm4"
application.language = "en_US.UTF-8"
application.process.session_id = "2"
Client #3
Owner Module: 10
Properties:
application.name = "xfce4-pulseaudio-plugin"
application.version = "0.4.1"
application.id = "org.xfce.pulseaudio-plugin"
application.icon_name = "multimedia-volume-control"
application.process.id = "663"
application.process.binary = "wrapper-2.0"
Client #6
Driver: module-x11-xsmp.c
Owner Module: 24
Properties:
application.name = "XSMP Session on xfce4-session as 24eb6ba54-a63b-4cd6-9981-266f1276984a"
xsmp.vendor = "xfce4-session"
xsmp.client.id = "24eb6ba54-a63b-4cd6-9981-266f1276984a"
Client #267
Owner Module: 10
Properties:
application.name = "AudioIPC Server"
application.process.id = "21335"
application.process.binary = "firefox"
application.icon_name = "firefox"
Client #275
Owner Module: 10
Properties:
application.name = "pactl"
application.process.id = "4097"
application.process.binary = "pactl"
Card #0
Owner Module: 6
Properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
device.description = "Built-in Audio"
Profiles:
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5965, available: yes)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: yes)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: yes)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: yes)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input-internal-mic: Internal Microphone (priority: 8900, latency offset: 0 usec)
Properties:
device.icon_name = "audio-input-microphone"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3+input:analog-stereo, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4+input:analog-stereo
analog-input-mic: Microphone (priority: 8700, latency offset: 0 usec, not available)
Properties:
analog-output-speaker: Speakers (priority: 10000, latency offset: 0 usec)
Properties:
device.icon_name = "audio-speakers"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (priority: 9000, latency offset: 0 usec, not available)
Properties:
device.icon_name = "audio-headphones"
hdmi-output-0: HDMI / DisplayPort (priority: 5900, latency offset: 0 usec, not available)
Properties:
device.icon_name = "video-display"
Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71, output:hdmi-surround71+input:analog-stereo
hdmi-output-1: HDMI / DisplayPort 2 (priority: 5800, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
hdmi-output-2: HDMI / DisplayPort 3 (priority: 5700, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
hdmi-output-3: HDMI / DisplayPort 4 (priority: 5600, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-stereo-extra3+input:analog-stereo, output:hdmi-surround-extra3, output:hdmi-surround-extra3+input:analog-stereo, output:hdmi-surround71-extra3, output:hdmi-surround71-extra3+input:analog-stereo
hdmi-output-4: HDMI / DisplayPort 5 (priority: 5500, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra4, output:hdmi-stereo-extra4+input:analog-stereo, output:hdmi-surround-extra4, output:hdmi-surround-extra4+input:analog-stereo, output:hdmi-surround71-extra4, output:hdmi-surround71-extra4+input:analog-stereo
