Details:
I was editing a track which I imported after saving the file from a Zoom recording. After spending hours editing the track with no issues, I added a music file which I had used on numerous podcast episodes before and Audacity then crashed (see the attached image of the error message that appeared). I then had no option but to ‘force quit’ the audacity app on my Mac as audacity was not responding, and this caused the file to be corrupted and I lost the track I had been editing. I have used audacity on my Windows laptop before and have not had this issue.
Could you please advise why this is happening?
I have generated the Audacity.zip file when it crashed but have not been able to attach it to this message.
I have followed your instructions and downloaded the updated version of Audacity; however, a similar problem is still happening and Audacity now crashes when I add a music track alongside the voice overs.
Do you have any other suggestions as to how I can work around this problem please? (see attached)
Screenshot 1- the wav of the song (I don’t use) #2- the mp3 (which I do drag into audacity) #3- the mp3 of the interview (because I deleted the data folder so I can’t open the .aup anymore, tg I saved it as an mp3 first) #4- the actual project where I combine everything and try to add additional audio tracks to
I just hate when we do that and there’s nothing wrong.
Are you close to overloading your machine? Probably not important, but we should remember that tiny convenient MP3 and M4A files explode to many times their apparent size because Audacity decompresses and mounts them as super high quality sound performances, not MP3.
Are you using cloud storage? Cloud drives mount as “just another drive” in your machine, but they are not just another drive. They can cause problems if the program isn’t ready for them, and Audacity isn’t.
